Wirsbo hePEX NEAR slab Repair
Tim Doran
Tim Doran Member Posts: 208
You should be able to get a QS20 fiting onto the stub. You can then continue on with PEX or what ever you like.
Tim D.
  • adayton_2
    adayton_2 Member Posts: 130
    hePEX burst near slab
    leaving only 2 or 3 inches exposed tubing. Need recommended repair procedure. The break is right under casement window/wall beam making usual 4 foot crimping tool usless. Tnx, Alfred
  • Scott Gregg
    Scott Gregg Member Posts: 187
    Use a Rehau Everlock fitting
    If it's not too late, Rehau's Everlock fitting will work on Wirsbo tubing. After you expand the tubing, Use a ratchet style tool to pull the sleeve up onto the fitting. This tool fits into most spots. It's all available from Rehau, and some local reps will loan or rent it out.
  • Tim Doran
    APR
    We also offer an Axiel Press Fitting with a ratchet style tool.
    Tim D.
