Steam heating Water geting into radiator Using too much water
Is your return clogged and leaking?
  • warren_2
    warren_2 Member Posts: 2
    The steam system is building water in some radiators
    I was frequently filling the water on my steam heating system that is a manual feed.Several radiators had water in them. I emptied the water and I had the shutoffs that were leaking replaced and all new vents installed, Iam still having the problem of water in the radiator and needing to fill the water frequently. What could be causing this??
  • bob young
    bob young Member Posts: 2,177
    check pitch of radiator
