Zone vale and hydro coil
Joe Mattiello_2
Member Posts: 94
Attached is the instruction sheet for the geothermal valve, with a good wiring diagram. Hopefully this helps you.
Got a ?? for ya...
there was a freedom hydro coil installed and has terminals Y.R.W.C.G we have taco zone vales 3 wire and robert shaw 9600 . both the air handler and zones valves run a 24v 40 va transformer , i need a wiring diagram for dummys Thanks for you help ...David0 -
;0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
