Bullhead Tee or is this OK?
Phil_6
Member Posts: 210
right to me
I recently had a new boiler installed. Attached is a pic of the tie-in point from the new steam pipe to the existing. Is this a Bullhead Tee or is it OK? Thanks0 -
Is there one or two take-offs from the boiler?
appears to be one. If so, it's not a bullheaded tee.
if you are feeding from two steam outlets
then that is not really the right way to pipe it, if on the other hand, if the right hand pipe is the drip (since this is a reducing 90 it looks like it might be) then you are ok. We would need to see the whole set up as it leaves and returns to the boiler0 -
Full picture
Here is a full picture from behind. The boiler is only piped from one steam supply.0 -
Any other thoughts?0 -
that's the drip so you are ok
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
