Steam Heat Thermostat
rbenny
Member Posts: 1
I have a fairly new heating system about 4-5 years old. A Burnham boiler and a Riello Burner. I have a Honeywell mechanical thermostat. Currently the way it is setup, I set the thermostat to 63 degrees. The system turns on about 62 and turns off at 71 degrees. I am considering installing a digital thermostat. I have been told you cannot program a "range" into the thermostat. If you set it to 68, the system turns on at 67 and turns off at 68 or 69, depending on the thermostat.
Which way is more energy efficient. A large swing (8 degrees) or a small swing (2-3 degrees)
Rich B
Rich B
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
