Recommendations for high recoveryhot water heating
A fiend has asked for hot water help. The house has gas forced air heat. The standard 50 gas gas hot water heater has too little recovery for his large family / peak demand periods. Would a small high efficency boiler, with indirect storage be a alaternate? An additional problem is the cramped utility room with barely the space for the existing tank size. What are suggested alternatives?
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,599
    showers?
    Hello: If the peak demand is from showering, you might want to look up the GFX shower heat exchanger. It can capture 60% of the heat going down the drain. Possibly the GFX could prevent the need for added heating capacity and save some energy $ in the long term.
    Yours, Larry
  • D lux_2
    D lux_2 Member Posts: 230
    Larry I
    Was thinking about using one w/ a rinni what do you think? thanks
  • Ted Robinson
    Ted Robinson Member Posts: 126
    Recover hot water?
    The construction of this condo would not suit the proposed heat recovery technique.
  • CSK
    CSK Member Posts: 2
    Check for Rebates
    You may want to look into a small munchkin on top of an indirect. You don't use up space and you now have a high efficient system which may qualify for rebates (check with your gas company on boiler and indirect). Another good option on this type of system (or any type) is a 3-way mixing valve. You now can set the tank at 140 degrees and use return water to temper down.
  • JackFre
    JackFre Member Posts: 225
    This is a perfect ap for Rinnai Continuum
    4.5 gpm @ 70F temp rise...all day long. Direct vent (5.25" OD). 82-87EF. $300 rebate on nat'l gas in this area. Beginning Jan 1 there is a$300 fed tax credit on Rinnai's. Very compact unit. Try www.rinnaisolutions.com.
