setting of aqaustat on boiler
Robert_15
Robert_15 Member Posts: 62
what setting do you do for a c.i. boiler with an outdoor reset control example 180f with a 30d differenial, does the o.d.r setting work below the high and above the low temp setting on the boilers control? looking to control the inside temp of boiler (boiler termonator)with the bypass valve half closed on the supply?
