HOT water boost...
kevin coppinger_4
Member Posts: 2,124
is not a lot..maybe 1.5 gal/min. Rinnai would work if gas were an option...venting is the issue here...roof is 25" high and in the middle of a LARGE room....electric is my only viable option. I looked at the electric tankless htrs but they don't say how high they can go w/ temp.....kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have a client...
that has a 40 gas water heater to heat water for a parts washer...it has worked ok for now but he needs to boost the water tem to 170F....water heater only goes to 150F...Is there a booster (pref. electric) to install after the water heater to give 20gals too meet his 20gal or so needs? ty, kpc
I'd recommend a Rinnai 2532FFUC
One question? What is his flow rate requirement? I'd run the tank at about 140 and let the Rinnai pick up the last 40F. Another point, be aware that as your output temp rises so to does the amount of precipitant that will come out of the water. Check your water quality first. If it has good water, it will walk away with this load.0 -
ps...water quality
s good. city water. kpc
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 986 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
