Nipple Size
Steve Garson_2
Member Posts: 712
I would use nipples that are at least 8-inches, if you have the headroom. You want the vent to open after a steam cycle, so keeping them away from the main helps them cool faster so the radiators don't have to breathe in too much.
Steve from Denver, CO
Nipple Size
I need to replace the main vents on my single pipe steam system. Do the new vents need nipples? If yes, how long? And why would I need them?
Thanks for your help,
Michael0 -
Nipple Size
Michael0 -
Nipples
The nipple sizes depend on the size of the fitting that you're going in to and the lengths are determined by their locations on the main.
Anthony Menafro0 -
Nipple length formula?
How would I determine nipple length?
Michael0 -
More nipple questions...
Steve,
Thanks for the reply. 3 more questions: Is there some formula that determines nipple length? I have only 5 to 6 inches of headroom, can the nipples be slanted? Doesnt the vents on the radiators keep them from breathing in too much?
Michael
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
