Radiator Conversion
Bob W._3
Bob W._3 Member Posts: 561
Are the radiator sections connected at the top as well as the bottom? If there is only a bottom manifold, it would be difficult to use.
  • John D._2
    John D._2 Member Posts: 3
    I have a radiator that I would like to use in a hot water application.
    The radiator was previously used in a 1 pipe steam system.
    Can I use it in a hot water application?
    One of my concerns is the vent is a little more than half way up.
    Should this vent be nearer to the top of the rad.?
  • John D._2
    The radiator is connected at the top, but it is difficult to determine if they are open. I may have to attempt the trial and error method.
  • Bob W._3
    Post pictures of the radiators, with the top connection.
