Temperature of a water boiler
bob young
bob young Member Posts: 2,177
ther should be an aquastat on the boiler. raise hi limit to 180*
  • Jeffbuko
    Jeffbuko Member Posts: 1
    Water temerature in boiler
    I am a hoeowner in my new residence for the first winter. The temperature reading on the boiler reads 140 degrees. I have cast iron radiators on the main level and newer baseboard heaters upstairs. I don't think the water temperature is hot enough because pumps are working radiatotrs are hot to the touch, but the system is struggling to keep the house above 66-68 degress. My question is can I regulate the temperature of the water at the boiler or is it controlled only through the thermostat.
