Removing vents
Empire_2
Empire_2 Member Posts: 2,340
Try channel lock plyers, but don't really reef on it. You can try penetrating oil if you are worried, but it should come. If it's old, just like grandma:) you know sometimes it takes A-Little more persuation, but be gentle....If that makes any sense...
  • Rich Baker
    Rich Baker Member Posts: 12
    Removing vents
    In a one pipe steam system, what is the best way to remove the vents that will not turn with just hand pressure, And if they break at the stem, then what?
