Replacement Radiators
gerry gill
Member Posts: 3,078
use radiant floor heat?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
Small (in height) Radiator
We are building out our kitchen and making two entire walls glass windows that will go to the floor (with only the window frame between the floor and the glass).
Is there any radiator that we can get that is extremely small (takes up no more than two inches in height) that we could run along the window wall? We have seen the Runtal and other manufacturer panel radiators but they require at least 5 to 6 inches of height. We have hot water radiaters in the rest of our house and had hoped to extend the system to the new space.
Thanks.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
