This Knight takes a high PHP stand
Jason Quinn
Member Posts: 96
In general, does the cost justify the labor savings? I am not familiar with this product, but it appears to be a unique concept.
Precision Hydronic Products sent
this new Lochinvar Knight stand for review. Ships in a LARGE box on a pallet.
Assembly took about 10 minutes! Nice quality and workmanship. Grundfos circs, Taco fill and zone valves. Circ zone packages are also available. Even the expansion tank gets a nice perch. This has DHW indirect ports on the bottom also. They also have these systems for other brands of boilers. www.phpinc.com
hot rod
Link?
Your address is getting me to a health care site
It takes the boiler room in a box concept
a couple steps further. By supplying the stand, expansion tank mount and some spare strut space to chose and add your own control package.
I guess a couple days labor to site build that on a wall. depending on your labor rate...
As a one man shop I could run service calls for those two days and easily offset the cost. Plus it is mechanically correct. Certainly a big plus for newbies.
Just another option for installers. I think our friend Tom Simensen from Montana had a hand in it's design. Certainly has a contractors touch to it.
hot rod
PHP vs Hydrolink
I am a newbie and wonder how you would compare the labor/material savings of the PHP to the labor/material savings of the Caleffi hydrolink?0 -
Labor wise
The PHP stand needs only to be assembled and connected to the zone piping.
I use the HydroLinks also on some jobs. They basically offer you a primary/ secondary in a steel box. The boiler piping would still need to be built at the site.
I'm curious to see who will offer a prebuilt panel, or stand with the Caleffi components.
Watts Radiant sure is in an ideal position to poffer that package in their Hydronix line
hot rod
panels
I think a panel with Caleffi components would be great. So who's game? ;-)0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
