Water hammer/ Hardford loop
Norm Harvey
Member Posts: 684
Post some pictures of the loop and near boiler piping, and we can better identify any problems.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=395&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I am getting a lots of water hammer in the hardford loop. Does any of you guys have and advise for this problem?
Thanks, John0 -
things to check
Hi John,
Water hammer in the Hartford loop can happen if the horizontal portion is too long or positioned too close to the waterline. Every manufacturer recommends the horizontal portion to be at most a close nipple. Anything more than that gives the potential to set up water hammer. It is also generally agreed that the horizontal portion should be between 2 to 4" below the normal waterline. I like 2" for gravity return and 4" for pumped return, but thats just me.
Does the hammer happen when the pressure is the highest, like the end of a long burner run cycle?
Best regards, Pat0
- 87.5K THE MAIN WALL
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
