Low pressure gauges
Charles_8
Member Posts: 74
The first hit on my Google search for low pressure gauges showed this:
http://www.gaugestore.com/products.asp?dept=1123
I don't know how good a deal $32 is, but at least you could watch the needle swing :)
-Charles
-Charles
LP gauge
What are you using this gauge for? How big of a gauge are you talking about?0 -
gauge
Charles I use a Marshalltown G22684 gauge.It has a range of 0 to 60 ounces psi . Very accurate . WWW.MARSHBELLOFRAM.COM then search G22684. Good Luck0 -
Ashcroft Low Pressure Gauge
I got mine from http://www.tristatetechnicalsales.com
I got the Ashcroft 0-60inH2O gauge and the snubber. Without the snubber odds are good that you'll destroy the gauge the first cycle the boiler runs.0 -
McMaster.com
P/N 4026K11
0-10 oz/sqin Max Temp 140deg F
$48.00
- 129 Chimneys & Flues
