forced air to hot water conversion
don_185
Member Posts: 312
sounds like a great system for heat.Whats the appoach for
good indoor air quality and cooling the structure?
Personally..I would do some panels rads size with a greater surface area and lower water temps and then add a hydronic
coil to give me a quicker responce on the very cold days.
Along with some chance for some IAQ.
Give me back my walls!!
conversion to hot water/boiler from forced air
I have a 2 story center hall colonial...unfinished basement...3200 sq.ft.central NJ...typical temps 25 degrees F daytime.... My heating contractor is suggesting "ultra-fin" for the first floor/floor and Haydon model 750 baseboard for the 2nd floor....The boiler..Weil-Mclain CGa6 using the 6"B-vent that will be abondoned from the furnace...to be certain a 2nd heat calc. is being run....all that said...whats your opinion???0
