gas conv. blower direction??
Brad White
Member Posts: 2,399
Does a draft/pressure check tell you anything?
Also, if it is a forward-curve blower (many small blades more tightly spaced), the "cup" of the blade faces the direction of rotation. (Think if an aggressive swimming stroke with cupped hands.)
FC blowers are common in the smaller sizes so this is my first instinct.
Backward-inclined or airfoil blades, the opposite is true; the blade backs face the direction of rotation, sort of like inducing flow with a gentle back-slap :)
-Ernie White, my Dad
blower ....clockwise, counterclockwise?????
I had a gas tech wire up a new blower on a gas conversion, he was confused on the fan direction!!.....it's easy to change, just invert the plug. How do i find out what direction the fan need to be turning?????0 -
man. rep.
e-mail manufacturers engineering dept----pronto. not in directions ??0 -
easy to change
"just invert the plug" LOL
I used to love saying that. But too many tried it then got mad:-)
Or, "I've cut down this @*#& piece of pipe three times and its STILL too short!"Terry T
steam; proportioned minitube; trapless; jet pump return; vac vent. New Yorker CGS30C
Direction?
Is this blower part of the burner gun or is this blower the indoor air/evaporator blower?0
