Solar Panels
> Dave, are you from New Jersey? <BR>
> <BR>
> Paul <BR>
> Pollets<BR>
> <BR>
> _A <BR>
> HREF="http://www.heatinghelp.com/getListed.cfm?id= <BR>
> 104&Step=30"_To Learn More About This <BR>
> Professional, Click Here to Visit Their Ad in <BR>
> "Find A Professional"_/A_ <BR>
<BR>
  • Dave Long
    Dave Long Member Posts: 1
    Solar Panels
    Does anyone have experience with how long it takes to recover the cost associated with augmenting a radiant heat system with solar panels in conjunction with a boiler?
    Also, which controls are the most reliable and efficient when using a boiler in conjunction with solar panels?
  • Constantin
    Constantin Member Posts: 3,796
    It depends on a lot of factors...
    ... location, insolation, orientation, installed cost, etc.
    ... if you have a PC and a copy of MS Excel, I highly recommend you check out the free retscreen cost/benefit models. They incorporate pretty up-to-date performance for all the stuff you can buy, have irradiation/insolation maps, etc. Nice work, even I'm not a great fan of using Windows-specific VB macros to get the job done.
    Installing the panels early in the life of the house (i.e. while it's being built) is usually going to be a lot cheaper than a retrofit later on. Optimizing the panels for winter pickup by installing them "steeper" than the latitude of the installation site is another common thing to do.
  • George Peteya_4
    George Peteya_4 Member Posts: 23
    New Jersey
    Paul, how can you tell? Is it something Dave said, or is it our over-use of prepositional phrases?
