boiler temp. problems
I have the following problem: it takes about an hour to get my water temp from 120 to 180, even after it has cycled for a night in cold weather. the house stays at set temp. but the gas bills are higher than expected. i put the boiler in September of this year. the following are my specs.:
75,000 input 60,000 output Bryant gas boiler
60 feet fin baseboard
835 sq. foot house
7 degree delta on my supply/return lines
235 net stack temp.
house has newer windows and insulation
10 feet piping in garaged but it is wrapped.
thanks for any ideas, Roger Decker RW Decker Heating
  • Empire_2
    Empire_2 Member Posts: 2,340
    Gas pressure?
    Has the manifold pressure been taken? 3.5"???? Hi Eff. or 80%? If 80 % your stack is lo...... One more Q:, What size lines supply your base?
    Mike T.
