Need Tekmar Gurus !!!!
Ted_9
Member Posts: 1,718
I'd set it up with a Vitotronic control.
Massachusetts
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Massachusetts
How would you set up Tekmar 260 to control boiler water temperature between 125*F to 145*F and not exceed the 145*F temperature by 5 *F or as close as possible? Boiler is a Vitola with IDWH.
Tekmar 260 has OD & ID sensors, controlling 4 zones of Slant Fin 30/¾ convectors that wrap around exterior walls in all upstairs Bedrooms & Baths.
Downstairs consists of Kitchen/Dining room with 12 of convector on a sidewall. Living Room has 16 of convector on a sidewall.
There no convectors across the front or back of Living Room, Kitchen /Dining areas.
Tekmar
Control is already in place. Thanks for your reply.0 -
tekmar 260
Ernie,
I'm not sure why you want to do this, because it mainly bypasses most of features of the Tekmar 260, which is a great control.
However, you could set the maximum boiler target temperature at 145 degrees and the minimum boiler target temperaturs at 125 degrees. Then I would monitor the actual temperature to see how close you get.
You can download the data file for the Tekmar 260 and any other tekmar control at Tekmarcontrols.com
I must ask though, with indoor sensors and outdoor sensors, why would you want to do this?
Respectfully,
Paul B. Shay
pshay@arealgoodplumber.com
LMP 1307
LMFS 654B
212-505-1837
917-939-0593
OUR MISSION: TO PROVIDE WORLD CLASS PLUMBING, HEATING, AND SPRINKLER SERVICE TO EACH AND EVERY CLIENT WE SERVE, FAR EXCEEDING THEIR HIGHEST EXPECTATIONS!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
Paul
I am trying to achieve constant circulation in all zones with the lowest water temperatures possible. Thanks for your reply.0 -
Tekmar controls
Do you have a sensor on your supply line? set your min. and max temperatures, also set your differential, if you are worried about overshooting your supply temp. you certainly don't need a viessmann comtrol,although Veissmann has great stuff! I've been using Tekmar for a loooong time and have NEVER had any reason to switch.0 -
Vitola
How did you purchase the Vitola without the Viessmann control. They will not sell any boilers except the ECDS and Vitorond 100. It would run flawless with one of the Viessmann controls, not to say anything about Tekmar, they make high quality products as well. Marc0 -
Dave
Yes it has a supply sensor. Would you use the auto adjust differential or set it for what you want?0 -
Marc
Vitola installed in 1991, with simple on/off....summer/winter switches and dial temperature control set @ 150*F. Temperature setting was more than enough to heat @ design day.0 -
Jimmy The Gent Burke from Comfort zone
He has an ad here and his email is baseheat@aol.com . He is who I go to when I can't figure it out. Mad Dog
Give me a call.........
Ernie,
Hey Ernie, How are you? Give me a call and I will talk you through it.
My cell phone number is 1-203-921-6310.
I'll be at the homeshow in Stamford March 3-4th if you want to talk to me there too. The phone is better when I can look up the Tekmar books while in front of the computer.
John Ruhnke
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"I am the walking Deadman
Hydronics Designer
Hydronics is the most comfortable and energy efficient HVAC system.0 -
John Runke
Thanks John, when is the best time to call. Ernie0 -
MAD DOG
Thanks for your reply, appreciate your input,Ernie0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
