Pump Sizing
Tom Krell
Member Posts: 1
I have a customer with a 168,000 Boiler in a 3 story row house. The house has 3 stories plus a basement. The boiler is in the basement. He currently has a B&G 100. Can I replace it with a Taco 007?
size?
arAre you sure the B7G100 was correct? Measure the building as described by Dan H. Pipe size at circ. longest possible run and figure the head at 6'per 100'of run. its the simplest way to get the correct size. Go to Tech tpoics , type in "how to size circulators" ant its right there. Hope this helps.
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
