CI Baseboard on one pipe steam.
Steamhead (in transit)
Member Posts: 6,688
just make sure the loop seal is at least 3 feet deep. I'd also add a drain for flushing it out if needed.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Need to add 9 feet of cast iron baseboard to one pipe steam syst
I drew a picture of what I want to do. I am pretty sure I saw in the laosh that you could do this but I can't find it anywhere. I wanr to drop the return line down below the main and then loop up and create a trap and then tie the return into the bottom of the supply. Seems like it would work. Has anyone ever done this? Do you think this will work?
I will do that.
Thank you
