bypass valve??
Paul_11
Member Posts: 210
Is your boiler steam or hot water?
Do you have a mixing valve or electronic control of some type?
Steel can be destroyed as well as cast iron with flue gas condensation.
Respectfully,
Paul B. Shay
pshay@arealgoodplumber.com
LMP 1307
LMFS 654B
OUR MISSION: TO PROVIDE WORLD CLASS PLUMBING, HEATING, AND SPRINKLER SERVICE TO EACH AND EVERY CLIENT WE SERVE, FAR EXCEEDING THEIR HIGHEST EXPECTATIONS!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=236&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Respectfully,
Paul B. Shay
LMP 1307
LMFS 654B
Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-0593
NYC LMP: 1307
O:212-505-1837
M:917-939-0593
I have a steel boiler with 2 zones of baseboard....The plumber who put in the system piped a bypass valve in. I was under the impression that they were only needed on cast iron boilers?? Is this true and the way its piped it it goes from the supply to the boiler side of the circultor...
if i dont need it, should i just close the valve???0 -
it is a steel..hot water boiler..with domestic coil ( although not using)...so then its better to keep the by pass open to keep the boil;er hotter to prevent the condensation of the flue gas???0 -
bypass
Is your bypass just a ball valve? That really isn't proper boiler protection. Dd you have any way of monitoring the return temperature when the system is running?
Here is one example of a proper bypass valve.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
