Searching for Steam System Specialist in South Jersey
DanHolohan
Member, Moderator, Administrator Posts: 16,601
for him to have a Find a Pro ad here as well, eh?
Retired and loving it.
Searching for a Steam System Specialist in South Jersey
Our house is heated by an old 2-pipe steam system. We have done some research on how these systems are supposed to work and know that even though ours has been providing heat to our home, it has not been working properly. This year it doesn't seem to be working at all. We are looking for a professional who knows his way around a steam system and can troubleshoot the entire system from top to bottom. We live in Camden County in South Jersey. We have had our fair share of "knuckleheads" (to quote Dan Holohan) tinker with our system, and we're sure they've made it worse. We need a true expert. Any recommendations/suggestions? Thanks.0 -
if you'd like to give me a call you may do so at 267-278-0588. thx. we may be able to help.0 -
Perhaps
you should have a Find a Professional ad here on this site?Retired and loving it.0 -
perhaps, but i do mostly commercial/industrial and dont want to get heavy into residential at this time, but if there is a customer who is truly in need and there is not someone else here to service them properly, i will work with them.0 -
We get a lot more
than residential customers on this site. Some very large jobs have come from Find a Pro ads. Oh, and it helps support this site. Everyone wins. ;-) Thanks for considering it.Retired and loving it.0 -
Alternative method to finding the experts
An alternative to finding a contractor who knows his business with steam systems (or hot water boilers) is to contact a well known mechanical engineering firm. They will be familiar with commercial contractors and residential types that prolly work on older systems or that modify the older systems to newer standards. Its only gonna cost you a bit of time ot make some phone calls. Best of luck to you.0 -
Still Without Heat
I wanted to say thanks to those who responded to our original posting - I will be following up with their suggestions. Sorry for the delay, but our computer has been on the fritz as well as our heating system.
In the meantime, we were connected to a residential heating guy (through another heating company that couldn't help us). He seemed to know his way around a steam system and confirmed for us what we already thought - the vent trap is not working, so the system is backing up with air and water, which means there is no room for the steam that is being generated in the boiler to move up and into the radiators. He went away without charging us and told us he would look to see if there was a replacement part that could be fitted into our old system. Despite repeated calls to the guy, we haven't heard from him since.
So...this is what we have:
Bryant Heater Company Tubular Gas Boiler
Boiler No. 3-443
Serial No. 309801
Steam Rating 660
Hourly BTU Input 198000
Water Rating 1060
Patents ranging from 1921-1936
Max W.P. Steam 15lbs. Water 50lbs.
and a
Webster Modulation Vent Trap
Is there any hope of finding a modern vent trap that can be retrofitted into this system?
Thanks.
Steam guy
There's a guy in Merchantville named Bill Alber that could likely help. He's a mechanical engineer with his own HVAC business called Alber Service. Actually he inherited the business from his father but whatever-he knows steam systems. 856-317-1750 I used to work for him. He's a good guy.There was an error rendering this rich post.
We'll Here's a job right here for you, Flange
My Ad here is the best advertsing dollars I ever spent. You'll spend more on Coffee for the year. Besides, don't you think its only fair to those of us who do pay for an ad. Just a thought. Thanks Mad Dog
Yep. I know your halfway between Steamhead and Me
Folks. Both of us travel on consulting for these systems. Either of us can tell you what's right, what's wrong and HOW!!!! to fix it. Then, all you have to do is find an honest local plumber to make the corrections. We do a lot of these. Here if you need us. Mad Dog
Thank You!
We would like to thank John Sibley for giving us Bill Alber's name. We contacted Alber Service, and they have successfully diagnosed and repaired our problem. We are so grateful to have heat again!
So, thank you, John Sibley. Thank you, Alber Service. And thank you, HeatingHelp.com for giving us a forum where we could get the help we needed.0 -
Makes you wonder
why they don't have ads in Find a Professional, doesn't it?Retired and loving it.0 -
good jobs & bad jobs
makes you think that maybe the guys that advertise here don't need that particular customer Dan. you explained it pretty clearly but no one seemed to pick it up.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
