church controls / low occupancy
I’m working on a church that is adding a multipurpose room (gym) to get kids involved plus a nursery, a couple of classrooms, kitchen, and a nursery. They want the building air conditioned with rooftop units. I recommended to the architect installing a boiler for baseboard, cabinet unit heaters, and radiant ceiling panels (entrances). I just thought why heat the space with rooftop units and we can make the building comfortable in low-occupancy.
All radiation, ceiling panels, cab heaters, are piped with zone valves, but I am wondering what is the best way to keep costs down. DDC controls in a church that no one can use?.
I could pipe the building with 3 zones, then use set back stats.
Any suggestions for controls for a church that is HIT or MISS with occupancy?
Everything is still on the drawing board.
Thanks for the help (churches are different)
  • church radiation
    I’m working on a church in Michigan that is adding a multipurpose room (gym) to get kids involved plus a nursery, a couple of classrooms, kitchen, and a nursery. They want the building air conditioned with rooftop units. I recommended to the architect installing a boiler for baseboard, cabinet unit heaters, and radiant ceiling panels (entrances). I just thought why heat the space with rooftop units and make the building comfortable in low-occupancy.
    All radiation is piped with zone valves, but I am wondering what is the best way to keep costs down. I hate to put DDC controls in a church that no one knows how to use.
    Everything is still on paper.
  • church radiation
    I’m working on a church that is adding a multipurpose room (gym) to get kids involved plus a nursery, a couple of classrooms, kitchen, and a nursery. They want the building air conditioned with rooftop units. I recommended to the architect installing a boiler for baseboard, cabinet unit heaters, and radiant ceiling panels (entrances). I just thought why heat the space when un-occupied with rooftop units and we can make the building comfortable in low-occupancy.
  • Joe_59
    Joe_59 Posts: 1
    church heat
    email me yr phone number. We have done seven so far and looking at more, be glad to help
  • Tim_24
    Tim_24 Posts: 53
    Ventilation
    is going to be the most signifcant design constraint, not heat. In a gym/multipurpose room, the occupancy can be very dense and obviously varying greatly in activity. The IMC requires 15 cfm/person in an Auditorium environment, 20/person in a Gym (playfloor) environment. A heated makeup air unit and exhaust fans will be required, at a minimum. If the kitchen is non-residential in any way, exhaust and makeup air will also require competent HVAC engineering. You mentioned a nursury, which will also have specific ventialtion requirements. Hire a PE. Churches are different, but not that different. In most jurisdictions in which I have designed HVAC systems for churches that included classrooms and/or nursuries, the sometimes lax constraints on churches did not apply.
  • Bill...
    ...have a look at tekmar tN4 Control Solutions at www.tekmarcontrols.com. OR call us at 250-545-7749. we would be more than happy to give you options available.
    Regards,
    Mike
