outdoor reset for WM
Timco
Member Posts: 3,040
Is outdoor reset available for a WM CGa gold boiler?
Online?
T
Online?
T
Tekmar 260
would work well for the CGa.0 -
Weil-McLain ODR
Several threads recently asking about a W-M outdoor reset. Option given were the Tekmar 265 and the W-M BCP-3, both a little on the pricey side according to some.
Another option is Weil-McLain's WM-ODR, part no. 389-900-210
cost 1/3 that of BCP-3, 1/6 that of the 265 (as priced through W-M).0 -
CGa reset
Try the Tekmar 256 or Honeywell AQ475 reset control.0 -
I don't want to hijack this thread
But I've notice little mention on The Wall of TACO's PC-700 as an alternative to Tekmar.0 -
Steve D.
The WM-ODR does not limit the low temperature of the reset and the installation manual warns about sustained operation below 140*. If your plumbing is not set up to accomodate this, look for something that limits lowest reset temp.
Steve0 -
265 --> 260
Hello Tim.
The 265 is a modulating boiler staging control, not used for the CG Series Boiler. However, it could be used on an Ultra Boiler from Weil McLain.
The 260 Boiler Control would be best suited, as mentioned by Bob.
If you have further questions, pelase contact tekmar at any time at 250-545-7749, Ext. 214.
Regards,
Mike0 -
That's good info
on the Tekmar. This a new line for us and I'm still waiting on my catalog. Ihad seen the 265 suggested on one threaed or another. The Ultra, BTW, needs no third party hardware for ODR, it is factory standard feature. I had quized Weil-McLain directly about ODR on the CGa and they suggested the WM-ODR.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
