Leaky valve
sam_20
Member Posts: 1
If my steam radiator is leaking from the seam in the valve, do I just remove the handle and stem, unscrew the valve, wrap it with plumbing tape, and re-attach? Is this fairly simple? Sorry for the basic question -- I'm new at this.
Thanks,
Steve
Thanks,
Steve
How to fix a leaky radiator valve
http://www.thisoldhouse.com/toh/video/heatingcooling/article/0,26206,1191164,00.html
This doesn't cover if the valve is leaking at the spud, I had a few in my house that did and ended up replacing the whole valve. I'm better off because now when it is closed it seals tight!0
