flame inside burner
craig_10
Member Posts: 7
it is natural gas and it is in an out building heating sand for a steel foundry. it calls for 7" in and im a little short the regulator is inaccessible durring production but it's been that way since installed in 90's.
flame inside burner
i am working on an enerco technical products vent free radiant heater. milivolt system. after the call for heat opens the gas control, a nice blue flame sweeps over the ceramic burners' face and all is well. for about 3 to 5 minutes then poof, the flame backs up and is inside the burner. i blew out the ceramic burners and made sure all the little holes were clear and checked gas pressure. when this happens on a conventional furnace i slow down the fuel mixture or replace the worn out ribbon burners. not sure what to do here.0 -
first problem
Vent free? Do you know how dangerous an appliance like that is?
That being said, is this natural or propane gas? You may need to check the gas pressure.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
