steam problem
You have a balance problem that is related to the vents. Replace the bad ones. If its been several years or more since they were changed, change them all. Install adjustable vents, set them all at 1/2 capacity, then adjust accordingly, more open if the room is cold, close it down if the room is hot. It ain't rocket science !!!
  • DennisV
    DennisV Member Posts: 10
    STEAM HEAT PROBLEM
    I have one zone steam heat system and does keep same the rooms cold now I turn off the radiator that was giving most heat and looks like the house is warmer and the rooms that was cold is nice. What that can be? Thank you!
