vintage furnace gas 3-way valve replacement
Stan Harris
Member Posts: 1
My 1926 Control-o-gas furnace 3-way valve must be repacked with grease often to stop leaking. Where can I purchase a replacement? My furnace company says they are no longer available and I must "upgrade" to a thermostat system. I'd rather keep the same manual system.
He's probably right
but can you post a pic so we can see it?
I have converted
those systems over to powerpile and they work great. That is the only alternative as the valves are no longer made and I used up the last repair kit I had for them about five years ago.
Just curious does your system have a cast iron combustion chamber?0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
