Had one of these this year??
Al Letellier_9
Member Posts: 929
this trade sure has its share of knuckleheads, doesn't it?? So glad we've got a bunch of good guys to offset the stupidity, from the guy who did the work originally to the one you mentioned was there before you. Good work>>>>>jsut hope you had a good ground fault for those heaters......
As you may guess, it was a hot pipe. Previous plumber sweated the copper back together, left the frozen insulation (ice blocks) in place and flew away with a check. I put two 1500W heaters in there, enclosed it with styro insulation boards and two days later could get up to the pipes, which burst where he had fixed them. Added freeze protection and a ton of insulation.
TimJust a guy running some pipes.0 -
I hope
you carved a swan or fish out of that, Tim. Shame to waste such an articulate block of ice.0
- 120 Geothermal
