Radiant question
Paul Fredricks_3
Member Posts: 1,556
One thing I don't know a lot about is radiant. We have a customer with one zone of radiant. Covers an area roughly 20 x 40, 2 rooms. He has insufficient heat, one side of the floor is warm, one side is cold. He tells me it is a single loop, 1/2" PEX, 1200 feet long, Taco 0010 pushing it and a Sparco 3/4" mix valve. Sounds way to long to me. No manifold, just one loop. It was recommended we try a bigger circulator.
What do you think?
What do you think?
reversing direction
add a 3 way valve to reverse flow direction( change direction every 15 minutes). can the zone be 'chopped' in half or thirds?0 -
long loop
That loop is insanely long. I think Mark Eatherton has done some work with reversing the flow periodically based on pump run-time. That might even the temperature a little.
I would try constant circulation on that zone with outdoor reset. That will give the system a chance to reach some sort of equilibrium. You might even do this in conjunction with the flow reversing valve. It will cost them, but 1200 feet is incredibly long.
edit: As jp said, If there is any way to break this loop into smaller pieces, that is the way to go.0 -
\"The Long Way Around\"
check out the April 2004 issue of www.pmmag.com for an article on long loop challanges. Siggy modeled a 1000 footer in the HDS software, in his monthly column there.
The 4 way reverser in that article made it's way to my shop for some data logging. Here is the printout of the mid point sensor on a 800 foot loop with that Paxton reverser flopping every 15 minutes. It actually did a great job of getting the middle of the loop to a reasonable temperature.
Paxton would love to get some more of those 4 way reversers out in the field. Contact Leif at www.paxton.com
hot rod
How Often?
Hot Rod,
Just curious. With all the do-it-yourselfers thinking in-floor distribution systems are a no-brainer do you run into this problem often?
I often offer ways to save to my customers $$$$ but I insist that they follow my layout in order to stick to my quotes.
I like equal length loops with a reverse return piping arrangement.
I apreciate the fact that there are remedies for poor design but pump life, debris turbulence and other problems must occur when flow directions are changed!
I am a product of bid and spec work for most of my career and design is almost always done by professionals. I truly have never run into this.
Rich K.
Thanks , I consider you amongst the best!
How Often?
How often to you run into this? Can there be that many poorly designed systems out there?
Rich K.
Make Peace Your Passion0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
