Barometric on Atmospheric
ttekushan_3
Member Posts: 964
Ever since I got a real combustion analyzer (the previous one was inflatable. Customers recognized buttons were made with a sharpie. Bad for business), I've come to the conclusion that the biggest problem with the traditional atmospheric boiler is the utter lack of control over excess air. Particularly newer boilers with very old and large chimneys.
Am I missing something obvious (and do tell if I am) or would it make sense to eliminate the draft hood and install a barometric damper instead, adjusting via analyzer readings?
If it does make sense, is this one of those issues that qualifies as changing the original equipment, thereby allowing lawyers to decide what is sensible and economical?
I'd appreciate any insights anyone would care to share on this subject-
-Terry
-Terry
Terry T
steam; proportioned minitube; trapless; jet pump return; vac vent. New Yorker CGS30C
i've done it..
but i've only done it when correcting an issue where the factory draft hood doesn't work well with the chimney..
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
