Peerless Pinnacle vs. Buderus GB14260
Dave_4
Member Posts: 1,404
Thanks Singh. I forgot to mention in my post that I DID have my windows replaced a few months ago. I'm guessing that my BTU/Hour usage sounds high because I didn't know the answers to some of the questions about the construction of my house that the software asks. To be on the safe side, I assumed the worst case scenario (i.e., minimal insullation. etc.).
Regards,
Gretchen
Regards,
Gretchen
Peerless Pinnacle vs Buderus GB14260
Hi-
I need a new boiler. I'm looking to replace my dinosaur model with a high efficiency gas hydronic.
I'm trying to decide between the Peerless Pinnacle and the Buderus GB14260. Do you have an opinion on which product is better?
Also, would you recommend purchasing a tekmar control package for either of them?
Thanks in advance for your help.
Gretchen
boiler comparisons
The Peerless is still quite new to the field and Buderus is a proven unit. I would go with the Buderus based on my limited exposure to the Peerless. Also, Tekmar and the GB don't always mate up. Buderus should have the controls you need to do the job.0 -
GB142
We have several in operation now. Not ONE issue.
The GB now comes with the AM-10 control as standard equipment. It does the OD reset, easy to program.
Mark H
Buderus
Hands down is superior to Peerless and I sell both. The are not close on any level...0 -
Questions?
Please contact me at Buderus if there are any questions on the GB142, wall hung condensing boiler or any other Buderus product 1-800-283-3787. Please remember with any condensing boiler, the low the system water temperature the greater the efficiency.0 -
Thanks to all for your reinforcement of Buderus. It helped me make up my mind.
Regards,
Gretchen0 -
Heat Loss Calculation
Hi all-
I need help sizing the new hydronic boiler that I plan to purchase (will likely go with the Buderus GB142). Using the Slant/Fin software available on this site and a lot of assumptions about the construction of my 1932 house, the software told me my heat loss calc is 71,534 BTU/HR. And, since my family is growing (just had #2 a few weeks ago) I may end up building an addition to my house down the road.
I live in the NY metro area, my house is 1400 square feet and I will also be getting an indirect water heater. Can anyone tell me what size hydronic gas boiler I'll need?
Thanks.
Gretchen0 -
Are you ready
From the heat loss calcs you gave, assuming there close,
You would be o.k with the GB142-24
The 24 is kilowatt. 1 KW=3414 btus .
If you're planning on a modest addition tou can bump up to a GB142-30.
The GB's can do the indirect tank , a larger hot water storage capacity may be needed, if family keeps growing : )
The 71,000 sounds large for a 1400 sq. ft house. Can you tightnen the place up a little with insulation , new windows if possible.
Congratulations on the new one.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
