air vent on old hydronic radiators
digger
Member Posts: 13
why are some manual vents near the top of the radiator while others are located about a third of the way down the side?
Hot water vs. Steam
Radiators used for hot water are tapped for the vent at the top where an air bubble would collect.
Radiators used with steam are tapped at the side, about a third off the bottom as the air is pushed from the top and bottom nipples to the center of the last section.
Radiators are traded from one system to another and people with drills make mistakes.
Long Beach Ed0 -
thanks for simple explaination.
I have a drill. Would it be a mistake to place the air vents at the tops of these radiators? I have already moved one as an experiment, and it worked.0 -
Is this
a steam or hot-water system?
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
