slow recovery for indirect water tank
ziptie (Denver)
Member Posts: 5
hello,
subject says it all:
double boiler system with 120 gal Rheem insulated tank for domestic hot feeding 12 500 sq ft one story units (finned baseboard). due to current denver cold snap (10F highs) the tank has been taking at least 1/2 a day to recover. my sense is that all units are calling for heat full time and the tank is low priority in the system.
any ideas on how to speed up this recovery time or to reprioritize the domestic hot?
thanks in advance,
ziptied in denver
thanks in advance,
ziptied in denver
Tekmar
It sounds like this system is a candidate for a Tekmer 262. Is the tank on priority at all right now? Is the heating system keeping up ok? What kind of boilers?0 -
make sure the tank is proiritized, the pipe is sized correctly for the btu's required to produce/recover the demand and that the pump is sized to overcome the pressure drop of the coil in the tank. Store the water at 180 and use a thermostatic mixing valve set at 120 to lengthen the draw time of the tank and give anti-scald protection. if usung zone valve, make sure it's full port.0 -
thanks for the replies guys.
this system in question has issues:(
once the temps allow i'm looking into a tekmer and will post what i come up with.
ziptie0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
