Radiator Won't Heat Up
Al Letellier_9
Member Posts: 929
have you checked the main valve itself. I've seen many where the vavle turns OK but the stem has snapped or the seat has fallen off the end of it and is blocking the steam as if it was turned off. If nothing else has changed in the system, I'd look at that main valve first. Does it get hot when you remove the vent altogether? IF so, it's a vent issue. If not, there is a blockage or the system is shutting down too soon.
I have a Gas/steam single pipe system in the northeast.
Last year this radiator worked ok. The pitch is good and I have tried several vent valves without any improvement. The master valve is hot to touch but the heater doesn't get hot at all. The rest of the system is good and relatively balanced.
Had a company come out they said the system could use a Squick cleaning and it should take care of the problem.
Any recommendations are appreciated.0 -
Just had the pro, JT Obrien, visit. They were very knowledgeable. The other company had no idea what to do. But this company was right on. Thanks0 -
What was the final fix?0 -
they lowered the pressure and added a steam cleaning agent. After a couple days it is better, but not 100%. Given that te problem is isolated to to 2 radiators. I most likely will asked them to come out and either clean out the radiator or replace the master valve. Just giving a few more days to let the cleaning agent work its course0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
