Pedestal sink
frank_25
Member Posts: 202
.....and I mean YEARS ago, those old pedistal basins were made from good ole cast iron and were truly free-standing. There were a couple of nuts and bolts holding the two pieces together, but sometimes there was a bit of a wobble inbetween the both of 'em and sometimes the floor. Thats where the plaster came into play. It filled in the gaps and made the whole assembly more sturdy. Todays pedistals are made from china, the basin needs to be bolted into the wall, and the use of silicone between the top and bottom, and between the sink and the wall is strongly recommended.
pedestal sink
I KNOW THIS IS NOT a heating question, but where will I find more plumber types than here.
I have taken apart a number of (old) pedestal sinks and I find that between the pedestal and the bowl is a lot of "plaster". What can I use today and how much do I use and how is it done?0 -
Ditto
I have a 1923 American-Standard pedestal lav in one of my baths, and used silicone between the bowl / stand. These things are heavy! But the fit is a lot better than most new ones tho.0 -
most useless plumbing fixture
Pedestal sink in my opinion are like the ties on men... Look good but useless.... Pita installing esp the newer one made in china. No storage spaces yet they want these in the powder room where there no storage spaces.... Have to take it off the wall to rod drain pipe in older homes...0 -
pedestal sinks
Most pedestals make it virtually impossible to make repairs if needed without removing the pedestal. I use a good quality latex tub and tile sealer. Silicone is extremely difficult to remove.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 995 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
