no heat 2nd floor
e boada
e boada Member Posts: 1
My 2800 sq/ft home has strong heat from radiators on first floor(where themostat is) but lacks heat on 2nd floor rads unless therm is cranked waaay up. Kawanee boiler, oil fired, just serviced and new valves installed on all rads. Rads checked for 5 degree tilt back to pipe (single pipe system) Any help?
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    2nd floor no heat
    The venting may be an issue or the cycle rate of the stat may to too short, shutting off the burner before all the rads are satisfied. If you have adjustable vents, slow downt the first floor and open the second floor vents more. IF you have an adjustable heat anticipator on your stat, turn it all the way up. IF problem persists, call in a pro.
