Banging Noises from Zone Valves
ALH_4
Member Posts: 1,790
It certainly can, and a <a href="http://www.caleffi.us/caleffi/en_US/Site/Products/Catalogue/args/sezione/Family030_Hydronic_valves/path/5~519~519-details/include/~applications~catalog~serie.jsp/index.sdo"target="_blank">differential pressure bypass valve</a> is the way to eliminate this possibility, particularly with higher flow rates.
Hi,
We have received solutions from the wall on this particular subject. The scenario is: circulator is on the return on almost all residential hot water boilers and the zone valves are usually on the supply. Due to the water velocity on the zone valve when closing you may get a banging sound. Solution: you may remove one spring from the Honeywell zone or move the zone valves to the return. i read the excellent book "Pumping Away." Page 50 shows the zone valve on the supply side of the pump. Humble question...Why wouldn't the zone valve create a banging sound when closing since it is so close to the discharge of the pump?
Thank You0 -
why not,
> It certainly can, and a _a
> catalog~serie.jsp/index.sdo"target="_blank"_differ
> ential pressure bypass valve_/a_ is the way to
> higher flow rates.
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
