radiant and domestic off of a water heater
> Would anyone here have any schematics and control <BR>
> stradagy <BR>
<BR>
I am running a Bradford White Combicore for domestic HW and Radiant. This unit has a heat exchanger built into the tanks to use for radiant heat.
For controls, you can use the same controls you would use with other heating sources, except you will always be heating the water in the tank and then modulating the temp with a mixing valve. I use a simple mixing valve, not one with outdoor reset. Be sure to use a flow check to avoid flow from convection.
Been working fine for five years.
Steve from Denver, CO
  • chris_40
    chris_40 Member Posts: 12
    I would like to know is it possible to run radiant heat and domestic hot water off of a water heater.Maybe use a flat plate heat exchanger for the radiant.any ideas.
  • Steve_35
    Steve_35 Member Posts: 545
    Yes, it's possible.
    And doing it with a heat exchanger of some sort is the only way we'd consider it.
  • chris_40
    Would anyone here have any schematics and control stradagy
