M tubing versus ACR
GW
GW Member Posts: 5,138
Thanks for the replies. I knew the basics; just didn't know where acr fit as far as wall thickness.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • GW
    stifferer
    we need to run some solar lines, and would like to minimize some soldering in the attic. Any pros/cons for soft tubing? Is M fine?
    What's the diff between soft L,M,and ACR? Anyone have any wall thicknesses?
    Thanks,
    GW
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    EBEBRATT-Ed Member Posts: 19,652
    L and acr are the same as far as I know. The only difference is that acr is cleaned dried and capped (and costs more) ACR come in 50 foot soft. L is 60 ft I think. I don't even know if M is available in soft. Never thoughtv about it b4. The wall thickness may be to thin for soft.
    ED
  • hr
    hr Member Posts: 6,106
    ACR
    sometimes seen with a blue marking on the hard drawn, the soft coil doesn't always have a color or incised marking, according the the CDA.
    5/8 ACR A (annealed soft) has a wall thickness of .035.
    M in 1/2 is .028, L is .040 and K is.049.
    ACR comes in off sized roll lengths for some reason?
    Schuco Solar has preinsulated linesets for their panel installations. Although it is a metric dimension. Looks and feels like an M wall thickness.
    Get ye a "Copper Tube Handbook" from the CDA at www.copper.org. Plenty of great info in this small booklet.
    hot rod
  • Techman
    Techman Member Posts: 2,143
    ABC's
    Hi Gary! ACR tubeing is L tube.Also comes in 3/4 O.D. ,capped & dehydrated & more $ and all sizes(ACR) are by O.D. and blue marking's .M is thinner wall ,K is thicker wall.Using a good bender(and eye) you can have many bend's w/o joints.50'coil's.
  • GW
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • Techman
    Gary
    No DIS meant or sent!I was being a wiseguy about the alphabet K-L-M ! I ask too many question's here to be uppity!
