W/M
T. Riley
T. Riley Member Posts: 26
I found a chart showing the heat loss from fluid inside various size steel pipe at varying temperature differences between the fluid and the air around the pipe. The heat loss is given in W/M. What is this? Is it watts per meter of pipe length?
