steam heat
val_4
Member Posts: 1
I have a steam boiler and 5 days ago I woke up to find a smell of something burning in the basement. I went and found the water level gauge of my boiler to be empty. I filled the boiler manually until the gauge was 1/2 to 3/4 full, but when I came back from work that day, I had the same problem: the water gauge was really low (not empty). It's been going on for the last 5 days and I am adding water like crazy very morning and every afternon after work. I have not found any leaks anywhere and my radiators are all working. What is going on?? Help
Val
Val
call someone...
asap...if you are having to add that much water you have a leak somwhere...maybe above the water line. Be VERY careful adding water to a near empty boiler..it could explode...wait until it is cold. Please call a steam person try the find a pro at the list up top....where aare you the the country? kpc
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
