rehau manifolds and telestat heads
clammy
Member Posts: 3,242
Wondering if some one can tell me the compatablity of rehau manifolds and telestat acturator heads for zoning soem radinat floors ,this system was installed by soem one else and they have already ran all the low voltage wiring but have not installed nor wired any it ,thgere's only 1 stat now riding the whole system lots of over heating .Mix down set up is manual with no low temp boiler protection ,the boiler piping lacks any flow checks ,air elimation and suffers from alot of heat migration from the 80 gallon indirect .System needs alot of work to finish andf set correctly and input on rehau manifolds and compatabity with telestat heads would be appricated thanks peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Call RST
Clammy, perhaps you may want to call RST, they are a rep in Mass for Rehau. I am sure one of the guys can answer all of your question. Their number is 781-320-9910. Good luck..0 -
Rehau telestats built for their manifolds. There is a 4 wire maniflod valve actuator for the Pro-Balance (part # 260166), and the Brass RA Adapter (part #260186).0
