Unit heat output
captbuderus
Member Posts: 10
I need to know the out put of Hot water unit heaters. I don't have a make but I was able to get model and serial.Model # is UHH-062A-A Serial# A401135 Measurements on these heater are 22" wide x 26 High. I also have another size, 16" wide x 20 high, model # UHH-028AA Serial # A404933 Thanks in advance for any info.
dont know these numbers...
they sound like small unit heaters around 18-> 24000 BTU/H ...
they have 3/4" taps on the right side...if they have take offs top and bottom they are steamers and the btu rating is less in a hydronic application.0 -
Re unit heaters
They are top/bottom feed, not side feed. They have 1 1/4-1 1/2 tappings, It is a more industrial type setting so I don't have to be perfect but I'd like to be colse. Could I find a similar size in a new heater and get close?0 -
I would think that the
062 and 028 numbers in the model number are the MBH ratings, probably at steam (215F) temperatures. These of course are nominal and would be de-rated for the actual water temperature.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
