tekmar
jp_2
Member Posts: 1,935
any computer store, or place that sells computers will sell line conditioners, if thats what I think you mean?
Tekmar 363
I recently have been having a problem with a Tekmar 363 control. Fault code ctrl EEW (in the manual it says most common cause for this, noisy power source or incoming line voltage interference). I went to www.tekmar controls.com and got a number for technical support. I called the company and the technician told me to install a line conditioner. I installed a line voltage monitor I could not find a line conditioner I don't know if there is any difference between a conditioner and a monitor. The call came back in same thing so, I called the company back and they told me they never had a problem with that fault code that the line conditioner did not fix. I did check my work when I installed it, it was working correctly according to the directions. This control has been in for at least three years and it has never had a problem until now. Any help would be greatly appreciated.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
