Munchkin to replace Laars
jeb
Member Posts: 46
<a href="http://www.laars.com/documents/heatsystems/2108C%20SV.pdf"target="_blank">LINK</a>
I have 2 Laars 9600HWG hooked up to 3 storage tanks. If you click on the link and look at page 9 thats what my setup is. One boiler has failed and I would like to replace it with a Munchkin VWH. When I look at the piping diagram for the Munchkin VWH I see one difference. The supply from the munchkin feeds the bottom port of the storage and the port above that feeds back to munchkin. The Laars is reverse. Does it matter?
Sounds okay.0 -
Does anyone have a opinion?
Thanks0 -
VWH
IF nothing has changed, the VWH Munchkin has constant circulation to the tank. Toward that end, the piping wouldn't make much difference in generating a standing tankful of hot water. My concern would be under extreme use, the tank may stratify, leaving consierably cooler water at the bottom causing thermal issues, like stress and sweating.
If you are cutting out the existing boiler, why not just use the piping in reverse, per the Munchkin manual? It would seem (from here) fairly simple at the boiler side.0 -
I have 2 boilers there and want to change only 1 thats why I wanted to leave the piping the same. Not sure if reversing the piping would affect the Laars.
Pete0 -
tank
On the tank side, I don't really see how it can. The incoming hot water is actually used as a catalyst to heat the colder water on the bottom of the tank, so I would only see things working better.
The constant circulation is something to keep in mind, as the Laars may not acclimate well to it depending on it's operating scheme. You can address that in the piping, so that the Laars stays more or less stable.0 -
The Munchkin feeds the bottom of the tank so you are not getting any sediment laying on the bottom into the coils in the boiler. reversing the Larrs should not affect its operation. Larrs should be able to answer you better though.
Kevin G0 -
Thanks for everyones replies. Did anyone think using a Munchkin VWH is better then the Laars? Cost wise they are about the same.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
