adjustable steam vents
I RECENTLY CHANGED THE VENTS ON MY RADIATORS WITH THE VARI VENT ANGLE VENTS AND NOW THE SECOND FLOOR RADATORS THAT DID NOT GET AS HOT TEND TO SPIT OUT ALOT OF WATER AND THE RADIATOR IN MY LLIVING ROOM ON THE FIRST FLOOR DOES THE SAME, ALL RADIATORS ARE PITCHED TOWARDS THE VALVE I THINK ITS THE VENTS BECAUSE IT DIDN'T DO IT BEFORE AND NOW THERE IS CONSTANT KNOCKING ON THE PIPES I DIDN'T HAVE THAT BEFORE, I DID A STEAM CLEANING ON IT AND TIL HAVE THE PROBLEM.
  • HitzKup_2
    HitzKup_2 Member Posts: 45
    vents
    The veri-vents are the fastest radiator vents, if you open them all the way you are very likely to over vent the radiators, so try to close them atleast halfway.
    HitzKup
